Saltar al contenido principal
Dell Latitude E5410 Screen Replacement
Qué necesitas
  1. Dell Latitude E5410 Screen Replacement, Dell Latitude E5410 Screen Replacement: paso 1, imagen 1 de 1
    • Have your laptop ready with your screen pulled all they way down parallel to the bottom of the laptop.
  2. Dell Latitude E5410 Screen Replacement: paso 2, imagen 1 de 1
    • Start on the top left or right corner of the screen edge and unscrew the small screws.
    • Be sure to remove the rubber placeholders in order to access the screws.
  3. Dell Latitude E5410 Screen Replacement: paso 3, imagen 1 de 2 Dell Latitude E5410 Screen Replacement: paso 3, imagen 2 de 2
    • Using a plastic opening tool, pry the bezel away from the screen.
  4. Dell Latitude E5410 Screen Replacement: paso 4, imagen 1 de 2 Dell Latitude E5410 Screen Replacement: paso 4, imagen 2 de 2
    • Use the Phillips screwdriver to remove the screws from corners around the screen.
  5. Dell Latitude E5410 Screen Replacement: paso 5, imagen 1 de 1
    • Remove the screws from both sides.
    • Once removed, they will release the screen.
  6. Dell Latitude E5410 Screen Replacement: paso 6, imagen 1 de 2 Dell Latitude E5410 Screen Replacement: paso 6, imagen 2 de 2
    • Use the spudger to move the sensor aside.
  7. Dell Latitude E5410 Screen Replacement: paso 7, imagen 1 de 2 Dell Latitude E5410 Screen Replacement: paso 7, imagen 2 de 2
    • Release the screen by pulling up and out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 15
Ultimos 30 días: 19
Todo El Tiempo: 2,745
