Saltar al contenido principal
Dell Latitude E4310 Display Replacement
Qué necesitas
  1. Dell Latitude E4310 Display Replacement, Battery: paso 1, imagen 1 de 1
    • Power down the laptop and remove all power cords.
  2. Dell Latitude E4310 Display Replacement: paso 2, imagen 1 de 2 Dell Latitude E4310 Display Replacement: paso 2, imagen 2 de 2
    • Push in the battery release button with your thumb.
    • Pull up on the battery to remove.
  3. Dell Latitude E4310 Display Replacement, Display: paso 3, imagen 1 de 3 Dell Latitude E4310 Display Replacement, Display: paso 3, imagen 2 de 3 Dell Latitude E4310 Display Replacement, Display: paso 3, imagen 3 de 3
    • Open up the laptop and flatten it down on a workable surface.
    • Turn it around so that the screen is closest to you.
    • Insert the flat end of a spudger, or plastic opening tool, into the groove between the screen bezel and top case.
    • Twist the spudger, or plastic opening tool, until you hear a clicking sound and continue doing this around the entirety of the display.
    • Remove the bezel.
  4. Dell Latitude E4310 Display Replacement: paso 4, imagen 1 de 2 Dell Latitude E4310 Display Replacement: paso 4, imagen 2 de 2
    • Remove the six 0.3mm Phillips #1 screws.
  5. Dell Latitude E4310 Display Replacement: paso 5, imagen 1 de 2 Dell Latitude E4310 Display Replacement: paso 5, imagen 2 de 2
    • Remove the two 0.5mm Phillips #1 screws.
    • There are two screws located at each corner. Only remove the ones closest to the outer edge.
  6. Dell Latitude E4310 Display Replacement: paso 6, imagen 1 de 2 Dell Latitude E4310 Display Replacement: paso 6, imagen 2 de 2
    • Carefully lift the screen up and flip it over onto the keyboard side as if you were turning the page of a book.
  7. Dell Latitude E4310 Display Replacement: paso 7, imagen 1 de 3 Dell Latitude E4310 Display Replacement: paso 7, imagen 2 de 3 Dell Latitude E4310 Display Replacement: paso 7, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use a pair of tweezers to flip the blue tape 180 degrees.
    • By flipping the tape you disconnect the display connector.
  8. Dell Latitude E4310 Display Replacement: paso 8, imagen 1 de 1
    • Remove the screen from the laptop.
Conclusión
5 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,504
