Saltar al contenido principal
Dell Latitude E4200 SSD Replacement
Qué necesitas
  1. Dell Latitude E4200 SSD Replacement, Back Panel: paso 1, imagen 1 de 1
    • Use PH0 screwdriver to unscrew the 4.49x7.88 mm screw in the middle of the back panel.
  2. Dell Latitude E4200 SSD Replacement: paso 2, imagen 1 de 3 Dell Latitude E4200 SSD Replacement: paso 2, imagen 2 de 3 Dell Latitude E4200 SSD Replacement: paso 2, imagen 3 de 3
    • Place thumbs flat on the front side of the back panel (the side to open the laptop).
    • Push panel upwards sliding it out of the locked position.
    • Lift panel out of socket.
  3. Dell Latitude E4200 SSD Replacement: paso 3, imagen 1 de 1
    • Remove panel and screw from the device. This opens up the main board of the device.
  4. Dell Latitude E4200 SSD Replacement, SSD: paso 4, imagen 1 de 1
    • Unscrew the two 4.10x4.05 mm screws holding the SSD in place.
  5. Dell Latitude E4200 SSD Replacement: paso 5, imagen 1 de 1
    • Using your finger and thumb lift the hard drive out of the computer but do not disconnect the attached connector to the computer.
  6. Dell Latitude E4200 SSD Replacement: paso 6, imagen 1 de 1
    • By applying pressure to the sides of the connector, pull the connector apart from the SSD.
Conclusión
6 personas más completaron esta guía.
Equipo
Baylor, Team 5-6, Williams Spring 2015 Miembro de Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Miembros
6 Guías creadas
Un comentario
You can use any mSATA SSD as replacement by using the following caddy/adapter:
https://www.ebay.fr/itm/166263029472
jacques_06 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 34
Todo El Tiempo: 8,402
