Saltar al contenido principal
Dell Latitude E4200 Keyboard Replacement
Qué necesitas
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: paso 1, imagen 1 de 1
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: paso 2, imagen 1 de 1
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: paso 3, imagen 1 de 1
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 1
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Latitude E4200 Keyboard Replacement: paso 5, imagen 2 de 2
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: paso 6, imagen 1 de 1
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: paso 7, imagen 1 de 1
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: paso 8, imagen 1 de 1
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: paso 9, imagen 1 de 1
    • Completely lift the keyboard from the device, as they are now disassembled.
Conclusión
3 personas más completaron esta guía.
Equipo
Baylor, Team 5-6, Williams Spring 2015 Miembro de Baylor, Team 5-6, Williams Spring 2015
BU-WILLIAMS-S15S5G6
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 4,312
