Saltar al contenido principal
Dell Latitude D830 Battery Replacement
Qué necesitas
  1. Dell Latitude D830 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Orient the laptop so the opening is facing you.
  2. Dell Latitude D830 Battery Replacement: paso 2, imagen 1 de 1
    • Flip the laptop over, so the opening is still facing you.
  3. Dell Latitude D830 Battery Replacement: paso 3, imagen 1 de 1
    • Place finger/ thumb on the slide button, then push the button forward
    • This unlocks the battery.
  4. Dell Latitude D830 Battery Replacement: paso 4, imagen 1 de 1
    • Place finger/thumb under the ledge.
  5. Dell Latitude D830 Battery Replacement: paso 5, imagen 1 de 1
    • Lift up the ledge, this allows the battery to be removed.
  6. Dell Latitude D830 Battery Replacement: paso 6, imagen 1 de 1
    • The battery is now removed.
  7. Dell Latitude D830 Battery Replacement: paso 7, imagen 1 de 1
    • To insert a new battery, orient the battery with the battery opening.
  8. Dell Latitude D830 Battery Replacement: paso 8, imagen 1 de 1
    • Insert the new battery with the left side being placed in first.
    • Press the new battery down until a "click" is heard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 420
