Saltar al contenido principal
Dell Latitude D630 Hard Drive Replacement
Qué necesitas
  1. Dell Latitude D630 Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: paso 2, imagen 1 de 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: paso 3, imagen 1 de 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: paso 3, imagen 2 de 3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: paso 3, imagen 3 de 3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: paso 4, imagen 1 de 1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: paso 5, imagen 1 de 2 Dell Latitude D630 Hard Drive Replacement: paso 5, imagen 2 de 2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
Conclusión
17 personas más completaron esta guía.
Savi Chavan
Miembro Desde 03/12/14
979 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 1-4, Cichon Spring 2014 Miembro de UMass Dartmouth, Team 1-4, Cichon Spring 2014
UMASSD-CICHON-S14S1G4
Miembros de 3
1 Guía escrita
4 comentarios
Dell latitude 2RHczd1
C Chandler - Contestar
I appreciate the guide my good sir. Very helpful.
Matt Erti - Contestar
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 35
Todo El Tiempo: 15,704
