Saltar al contenido principal
Dell Latitude D630 CMOS Battery Replacement
Qué necesitas
  1. Dell Latitude D630 CMOS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 CMOS Battery Replacement: paso 2, imagen 1 de 1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 CMOS Battery Replacement, Keyboard: paso 3, imagen 1 de 3 Dell Latitude D630 CMOS Battery Replacement, Keyboard: paso 3, imagen 2 de 3 Dell Latitude D630 CMOS Battery Replacement, Keyboard: paso 3, imagen 3 de 3
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 CMOS Battery Replacement: paso 4, imagen 1 de 1
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 CMOS Battery Replacement: paso 5, imagen 1 de 2 Dell Latitude D630 CMOS Battery Replacement: paso 5, imagen 2 de 2
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 CMOS Battery Replacement: paso 6, imagen 1 de 2 Dell Latitude D630 CMOS Battery Replacement: paso 6, imagen 2 de 2
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Dell Latitude D630 CMOS Battery Replacement, CMOS Battery: paso 7, imagen 1 de 1
    • Remove the connector to the coin using the spudger.
    • Slide the coin battery out of its slot by wiggling its connector with a gentle tug.
    • You may also need to use the spudger to carefully push out the battery from the top of the slot where the yellow square is.
Conclusión
33 personas más completaron esta guía.
Jon Amireh
Miembro Desde 01/17/13
1,698 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 6-1, Johann Winter 2013 Miembro de Cal Poly, Team 6-1, Johann Winter 2013
CPSU-JOHANN-W13S6G1
Miembros de 4
10 Guías creadas
9 comentarios
off topic but...in step 4, what is the component plugged into the white cable at the top left hand corner right above that screw?
Josh Henderson - Contestar
That looks like the Bluetooth module @Josh Henderson
stm reusables -
I love the easy-to-fix design of these older Dell Latitudes!
Joseph Sctbunio - Contestar
Worst CMOS battery placement I have seen. PPD
Lewis Balentine - Contestar
it is proving a lot harder to get the battery back in place than to remove it. More photos and guidence would be a helpful.
chefkevin1uk - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 118
Todo El Tiempo: 49,832
