Saltar al contenido principal
Dell Latitude D620 Display Replacement
Qué necesitas
  1. Dell Latitude D620 Display Replacement, Keyboard: paso 1, imagen 1 de 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 Display Replacement: paso 2, imagen 1 de 3 Dell Latitude D620 Display Replacement: paso 2, imagen 2 de 3 Dell Latitude D620 Display Replacement: paso 2, imagen 3 de 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: paso 3, imagen 1 de 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: paso 4, imagen 1 de 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: paso 5, imagen 1 de 2 Dell Latitude D620 Display Replacement: paso 5, imagen 2 de 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: paso 6, imagen 1 de 2 Dell Latitude D620 Display Replacement: paso 6, imagen 2 de 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: paso 7, imagen 1 de 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: paso 8, imagen 1 de 1
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: paso 9, imagen 1 de 1
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: paso 10, imagen 1 de 2 Dell Latitude D620 Display Replacement: paso 10, imagen 2 de 2
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: paso 11, imagen 1 de 2 Dell Latitude D620 Display Replacement: paso 11, imagen 2 de 2
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: paso 12, imagen 1 de 1
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: paso 13, imagen 1 de 1
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: paso 14, imagen 1 de 1
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: paso 15, imagen 1 de 1
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: paso 16, imagen 1 de 1
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: paso 17, imagen 1 de 1
    • Carefully lift the LCD screen out of its casing
Conclusión
19 personas más completaron esta guía.
Miguel Wong
Miembro Desde 04/15/10
562 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-35, Regan Spring 2010 Miembro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Miembros
4 Guías creadas
Un comentario
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 36
Todo El Tiempo: 33,211
