Saltar al contenido principal
Dell Latitude D620 CD Drive Replacement
Qué necesitas
  1. Dell Latitude D620 CD Drive Replacement, Keyboard: paso 1, imagen 1 de 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 CD Drive Replacement: paso 2, imagen 1 de 3 Dell Latitude D620 CD Drive Replacement: paso 2, imagen 2 de 3 Dell Latitude D620 CD Drive Replacement: paso 2, imagen 3 de 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 CD Drive Replacement: paso 3, imagen 1 de 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 CD Drive Replacement: paso 4, imagen 1 de 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 CD Drive Replacement: paso 5, imagen 1 de 2 Dell Latitude D620 CD Drive Replacement: paso 5, imagen 2 de 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 CD Drive Replacement: paso 6, imagen 1 de 2 Dell Latitude D620 CD Drive Replacement: paso 6, imagen 2 de 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 CD Drive Replacement: paso 7, imagen 1 de 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 CD Drive Replacement, CD Drive: paso 8, imagen 1 de 2 Dell Latitude D620 CD Drive Replacement, CD Drive: paso 8, imagen 2 de 2
    • Press in the tab on the bottom right side of the CD drive
    • The tab comes out on its own; there is no need to pull it out manually.
  9. Dell Latitude D620 CD Drive Replacement: paso 9, imagen 1 de 1
    • Gently pull the tab to remove the disk tray.
Conclusión
10 personas más completaron esta guía.
Ivan
Miembro Desde 04/15/10
194 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 24-35, Regan Spring 2010 Miembro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 8,372
