Saltar al contenido principal
Dell Latitude D610 Keyboard Replacement
Qué necesitas
  1. Dell Latitude D610 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude D610 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Dell Latitude D610 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Latitude D610 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Latitude D610 Keyboard Replacement: paso 2, imagen 3 de 3
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Dell Latitude D610 Keyboard Replacement: paso 3, imagen 1 de 1
    • Remove the battery from its compartment.
  4. Dell Latitude D610 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Latitude D610 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Latitude D610 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Use an opening tool or flat tool to remove the plastic cover above the keyboard.
  5. Dell Latitude D610 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Latitude D610 Keyboard Replacement: paso 5, imagen 2 de 2
    • Remove the two 3.9mm Philips #1 screws that are holding the keyboard in place.
  6. Dell Latitude D610 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Latitude D610 Keyboard Replacement: paso 6, imagen 2 de 2
    • Using an opening tool, carefully release the keyboard from the case.
    • Making sure not to tear or damage the wires still connecting it to the laptop.
  7. Dell Latitude D610 Keyboard Replacement: paso 7, imagen 1 de 3 Dell Latitude D610 Keyboard Replacement: paso 7, imagen 2 de 3 Dell Latitude D610 Keyboard Replacement: paso 7, imagen 3 de 3
    • Carfully lift the key board.
    • Lift only about 3 - 4 inches so that the wires holding the keyboard do not get damaged.
    • Pull on the blue tab to unplug the keyboard.
Conclusión
4 personas más completaron esta guía.
Jordan Barham
Miembro Desde 01/26/14
459 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 6-24, Maness Winter 2014 Miembro de Cal Poly, Team 6-24, Maness Winter 2014
CPSU-MANESS-W14S6G24
Miembros de 4
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 20
Todo El Tiempo: 2,055
