Saltar al contenido principal
Dell Latitude D600 Wireless WiFi Card Replacement
Qué necesitas
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: paso 1, imagen 1 de 1
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: paso 2, imagen 1 de 2 Dell Latitude D600 Wireless WiFi Card Replacement: paso 2, imagen 2 de 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: paso 3, imagen 1 de 1
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: paso 4, imagen 1 de 1
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: paso 5, imagen 1 de 1
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: paso 6, imagen 1 de 2 Dell Latitude D600 Wireless WiFi Card Replacement: paso 6, imagen 2 de 2
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: paso 7, imagen 1 de 2 Dell Latitude D600 Wireless WiFi Card Replacement: paso 7, imagen 2 de 2
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
Conclusión
6 personas más completaron esta guía.
Joseph
Miembro Desde 07/16/14
1,497 Reputación
5 Guías creadas
Un comentario
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,632
