Saltar al contenido principal
Dell Latitude D600 RAM (Main Memory) Replacement
Qué necesitas
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: paso 1, imagen 1 de 1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: paso 2, imagen 1 de 2 Dell Latitude D600 RAM (Main Memory) Replacement: paso 2, imagen 2 de 2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: paso 3, imagen 1 de 1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): paso 4, imagen 1 de 2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): paso 4, imagen 2 de 2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: paso 5, imagen 1 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: paso 5, imagen 2 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: paso 5, imagen 3 de 3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: paso 6, imagen 1 de 1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: paso 7, imagen 1 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: paso 7, imagen 2 de 3 Dell Latitude D600 RAM (Main Memory) Replacement: paso 7, imagen 3 de 3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: paso 8, imagen 1 de 1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
Conclusión
6 personas más completaron esta guía.
Joseph
Miembro Desde 07/16/14
1,497 Reputación
5 Guías creadas
Un comentario
Almost perfect: easy; clear;
Herman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 21
Todo El Tiempo: 2,847
