Saltar al contenido principal
Dell Latitude D600 Display Replacement
Qué necesitas
  1. Dell Latitude D600 Display Replacement, Display: paso 1, imagen 1 de 1
    • Remove the 6 screws underneath the rubber things - located in red
  2. Dell Latitude D600 Display Replacement: paso 2, imagen 1 de 2 Dell Latitude D600 Display Replacement: paso 2, imagen 2 de 2
    • Use your spudger to pry off the front case
    • Go all around the perimeter and pop it off
  3. Dell Latitude D600 Display Replacement: paso 3, imagen 1 de 1
    • Remove the 6 screws holding in the display screen
  4. Dell Latitude D600 Display Replacement: paso 4, imagen 1 de 3 Dell Latitude D600 Display Replacement: paso 4, imagen 2 de 3 Dell Latitude D600 Display Replacement: paso 4, imagen 3 de 3
    • Remove the screw holding in the display cable connector
    • Pull the black tab up to remove the display cable connector
  5. Dell Latitude D600 Display Replacement: paso 5, imagen 1 de 1
    • Slowly Remove the wire from the joints holding it in
  6. Dell Latitude D600 Display Replacement: paso 6, imagen 1 de 2 Dell Latitude D600 Display Replacement: paso 6, imagen 2 de 2
    • The computer is happy you are fixing him
    • Thats it, display is now removed feel free to replace it by doing the steps in reverse
Conclusión
3 personas más completaron esta guía.
Joseph
Miembro Desde 07/16/14
1,497 Reputación
5 Guías creadas
Un comentario
I see you removed the keyboard by seeing it in the background of the last image however, I do not see the steps instructing everyone on how to remove the keyboard.
Darren - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 2,083
