Saltar al contenido principal
Dell Latitude D430 Keyboard Replacement
Qué necesitas
  1. Dell Latitude D430 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Lay the laptop flat with the screen facing upward. This will allow you to have the most room while performing the keyboard replacement.
  2. Dell Latitude D430 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Latitude D430 Keyboard Replacement: paso 2, imagen 2 de 2
    • Identify the plastic cover located directly below the screen.
    • Carefully remove the plastic cover by lifting both ends of the cover.
    • This piece is very fragile, so be sure not to break this piece. It requires minimal force to remove this piece.
  3. Dell Latitude D430 Keyboard Replacement: paso 3, imagen 1 de 3 Dell Latitude D430 Keyboard Replacement: paso 3, imagen 2 de 3 Dell Latitude D430 Keyboard Replacement: paso 3, imagen 3 de 3
    • There are 3 screws that should be exposed now.
    • Use a Phillips 00 screwdriver to remove all 3 of the screws shown in the pictures.
  4. Dell Latitude D430 Keyboard Replacement: paso 4, imagen 1 de 3 Dell Latitude D430 Keyboard Replacement: paso 4, imagen 2 de 3 Dell Latitude D430 Keyboard Replacement: paso 4, imagen 3 de 3
    • Gently lift the keyboard from the top.
    • At the bottom of the keyboard, there will be ribbons connecting it to the motherboard. Be sure not to tear the ribbons.
    • Lift the clamps that are holding the ribbons in place in order to remove them. You should be able to remove the keyboard at this point.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 419
