Saltar al contenido principal
Dell Latitude 9510 Speakers Replacement
Qué necesitas
  1. Dell Latitude 9510 Speakers Replacement, Base Panel: paso 1, imagen 1 de 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Speakers Replacement: paso 2, imagen 1 de 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Speakers Replacement, Speakers: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  4. Dell Latitude 9510 Speakers Replacement: paso 4, imagen 1 de 1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
Conclusión
David Cauley
Miembro Desde 02/10/22
169 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 63
