Saltar al contenido principal
Dell Latitude 9510 Battery Replacement
Qué necesitas
  1. Dell Latitude 9510 Battery Replacement, Base Panel: paso 1, imagen 1 de 1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: paso 2, imagen 1 de 1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  4. Dell Latitude 9510 Battery Replacement: paso 4, imagen 1 de 1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
Conclusión
David Cauley
Miembro Desde 02/10/22
169 Reputación
2 Guías creadas
Un comentario
I have the Version with the 52 Wh battery.
Is it possible to upgrade my laptop to the 88 Wh battery?
Would appreciate any Insights on this!
Johann Mangelsen - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 26
Todo El Tiempo: 1,113
