Saltar al contenido principal
Dell Latitude 9410 2-in-1 Fan Replacement
Qué necesitas
  1. Dell Latitude 9410 2-in-1 Fan Replacement, Base Panel: paso 1, imagen 1 de 1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Fan Replacement: paso 2, imagen 1 de 2 Dell Latitude 9410 2-in-1 Fan Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Fan Replacement: paso 3, imagen 1 de 3 Dell Latitude 9410 2-in-1 Fan Replacement: paso 3, imagen 2 de 3 Dell Latitude 9410 2-in-1 Fan Replacement: paso 3, imagen 3 de 3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Fan Replacement, Fan: paso 4, imagen 1 de 3 Dell Latitude 9410 2-in-1 Fan Replacement, Fan: paso 4, imagen 2 de 3 Dell Latitude 9410 2-in-1 Fan Replacement, Fan: paso 4, imagen 3 de 3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Fan Replacement: paso 5, imagen 1 de 2 Dell Latitude 9410 2-in-1 Fan Replacement: paso 5, imagen 2 de 2
    • Use a Philips #00 screwdriver to remove the two 2 mm screws.
    • After the screws are removed, lift off the silver bracket, toward the top left of the fan.
  6. Dell Latitude 9410 2-in-1 Fan Replacement: paso 6, imagen 1 de 2 Dell Latitude 9410 2-in-1 Fan Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Grip both sides of the fan connector plug with tweezers, and pull directly backwards, toward the cables, until the plug disconnects.
  7. Dell Latitude 9410 2-in-1 Fan Replacement: paso 7, imagen 1 de 2 Dell Latitude 9410 2-in-1 Fan Replacement: paso 7, imagen 2 de 2
    • Lift the fan up and out.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 17
Todo El Tiempo: 411
