Saltar al contenido principal
Dell Latitude 7420 Display Replacement
Qué necesitas
  1. Dell Latitude 7420 Display Replacement, Back Case: paso 1, imagen 1 de 3 Dell Latitude 7420 Display Replacement, Back Case: paso 1, imagen 2 de 3 Dell Latitude 7420 Display Replacement, Back Case: paso 1, imagen 3 de 3
    • Remove the eight, 7 mm screws from the back case using a Phillips #0 screwdriver.
    • Use an opening pick or opening tool and work your way around the periphery of the base cover to separate it from the chassis.
  2. Dell Latitude 7420 Display Replacement, Display: paso 2, imagen 1 de 3 Dell Latitude 7420 Display Replacement, Display: paso 2, imagen 2 de 3 Dell Latitude 7420 Display Replacement, Display: paso 2, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the three, 2 mm screws fastening the cable covers.
    • Remove both cable covers.
  3. Dell Latitude 7420 Display Replacement: paso 3, imagen 1 de 2 Dell Latitude 7420 Display Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board to detach the coaxial cables from the Wi-Fi card.
    • Disconnect the remaining cables connecting the display assembly to the board.
  4. Dell Latitude 7420 Display Replacement: paso 4, imagen 1 de 3 Dell Latitude 7420 Display Replacement: paso 4, imagen 2 de 3 Dell Latitude 7420 Display Replacement: paso 4, imagen 3 de 3
    • Use a Phillips #00 screwdriver to remove the four 4 mm screws securing the display hinges.
    • There are two screws to remove from each hinge.
    • Lift the base to pull the display assembly free.
  5. Dell Latitude 7420 Display Replacement: paso 5, imagen 1 de 1
    • Separate the display assembly from the base of the laptop.
Conclusión
Una persona más ha completado esta guía.
nuredinroba
Miembro Desde 02/02/23
209 Reputación
1 Guía escrita
Equipo
Gateway, Team 1-2, Pee Spring 2023 Miembro de Gateway, Team 1-2, Pee Spring 2023
GCC-PEE-S23S1G2
Miembros de 4
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 32
Ultimos 30 días: 87
Todo El Tiempo: 1,823
