Saltar al contenido principal
Dell Latitude 7420 Battery Replacement
Qué necesitas
  1. Dell Latitude 7420 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude 7420 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the eight 7 mm screws from the from the back panel using the Phillips #1 screwdriver.
    • Please prevent the static damage by working from anti-static mat or wearing anti-static bracelet or touch the metal with hands to discharge.
  2. Dell Latitude 7420 Battery Replacement: paso 2, imagen 1 de 2 Dell Latitude 7420 Battery Replacement: paso 2, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Slide the opening pick in between the back cover and work your way around the edges to remove the back cover from the device.
    • Do not insert the pick tweezers too deep, since it may damage the other components on the motherboard.
  3. Dell Latitude 7420 Battery Replacement: paso 3, imagen 1 de 2 Dell Latitude 7420 Battery Replacement: paso 3, imagen 2 de 2
    • Using the Phillips #1 screwdriver, remove the five 5 mm screws.
  4. Dell Latitude 7420 Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery from the motherboard by gently pulling out the connector.
  5. Dell Latitude 7420 Battery Replacement: paso 5, imagen 1 de 2 Dell Latitude 7420 Battery Replacement: paso 5, imagen 2 de 2
    • Remove the battery from the laptop.
    • Before removing the battery from the laptop, please remove the cables that are attached on the battery.
Conclusión
5 personas más completaron esta guía.
Hong Lee
Miembro Desde 05/11/21
229 Reputación
1 Guía escrita
2 comentarios
Do you know if you can upgrade the battery i.e. go from 42 to 63? I noticed the voltages were different.
Andrew Violet - Contestar
One thing to be aware of is that if you order a replacement battery from Dell, they do NOT include the cable that connects the battery to the mobo! You need to reuse your old battery cable (and hope it's not bad).
Anna - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 79
Ultimos 30 días: 387
Todo El Tiempo: 14,265
