Saltar al contenido principal
Dell Latitude 7390 SSD Replacement
Qué necesitas
  1. Dell Latitude 7390 SSD Replacement, Bottom Panel: paso 1, imagen 1 de 1
    • Orient your Dell Latitude 7390 laptop so that it is facing towards you as if you're going to open it.
  2. Dell Latitude 7390 SSD Replacement: paso 2, imagen 1 de 3 Dell Latitude 7390 SSD Replacement: paso 2, imagen 2 de 3 Dell Latitude 7390 SSD Replacement: paso 2, imagen 3 de 3
    • Flip your laptop over so that the bottom is facing up.
  3. Dell Latitude 7390 SSD Replacement: paso 3, imagen 1 de 1
    • Using your Phillips #1 screwdriver, remove the eight 6 mm screws around the border of the bottom panel.
  4. Dell Latitude 7390 SSD Replacement: paso 4, imagen 1 de 2 Dell Latitude 7390 SSD Replacement: paso 4, imagen 2 de 2
    • Using an opening tool or picks, work your way around the periphery and pry the back case off.
  5. Dell Latitude 7390 SSD Replacement: paso 5, imagen 1 de 1
    • Finally, lift the back panel off to uncover the inside of your Dell Latitude 7390.
  6. Dell Latitude 7390 SSD Replacement, Battery: paso 6, imagen 1 de 1
    • Make sure the laptop is turned OFF and unplugged from the power adapter before taking the battery out.
    • Use the Phillips #1 screwdriver to remove the five 6 mm screws holding the battery in place along the edges of the battery.
  7. Dell Latitude 7390 SSD Replacement: paso 7, imagen 1 de 3 Dell Latitude 7390 SSD Replacement: paso 7, imagen 2 de 3 Dell Latitude 7390 SSD Replacement: paso 7, imagen 3 de 3
    • Be careful not to break the connector by pulling too hard on the black tab.
    • Pull the black tab on the top of the connector to unplug the battery from the motherboard.
  8. Dell Latitude 7390 SSD Replacement: paso 8, imagen 1 de 1
    • Carefully lift the battery out of the laptop.
  9. Dell Latitude 7390 SSD Replacement, Solid State Drive (SSD): paso 9, imagen 1 de 1
    • Using a Phillips screwdriver, remove the 6 mm screw from the SSD cover.
  10. Dell Latitude 7390 SSD Replacement: paso 10, imagen 1 de 1
    • Remove the SSD card from under the silver plate.
Conclusión
Thomas Pryor
Miembro Desde 02/22/22
86 Reputación
1 Guía escrita
Equipo
Clemson, Team 1-4, Hunter Spring 2022 Miembro de Clemson, Team 1-4, Hunter Spring 2022
CLEM-HUNTER-S22S1G4
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 17
Ultimos 30 días: 63
Todo El Tiempo: 2,968
