Saltar al contenido principal
Dell Latitude 5521 Wireless Card Replacement
Qué necesitas
  1. Dell Latitude 5521 Wireless Card Replacement, Base Cover Removal: paso 1, imagen 1 de 3 Dell Latitude 5521 Wireless Card Replacement, Base Cover Removal: paso 1, imagen 2 de 3 Dell Latitude 5521 Wireless Card Replacement, Base Cover Removal: paso 1, imagen 3 de 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Wireless Card Replacement, Wireless Card Removal: paso 2, imagen 1 de 3 Dell Latitude 5521 Wireless Card Replacement, Wireless Card Removal: paso 2, imagen 2 de 3 Dell Latitude 5521 Wireless Card Replacement, Wireless Card Removal: paso 2, imagen 3 de 3
    • Locate the wireless card.
    • Remove the one screw holding the card in using your PH0 bit.
    • Remove the bracket holding the wireless card in.
    • Remember the orientation of the bracket for reinstallation.
    • Remove the black and white wires from the wireless card.
    • For reinstallation it helps to push on the top of the connector to get it seated. Top being the end opposite where the wire comes into the connector.
Conclusión
Michael Engle
Miembro Desde 10/14/21
461 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 232
