Saltar al contenido principal
Dell Latitude 5521 Solid-State Drive Replacement
Qué necesitas
  1. Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: paso 1, imagen 1 de 3 Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: paso 1, imagen 2 de 3 Dell Latitude 5521 Solid-State Drive Replacement, Base Cover Removal: paso 1, imagen 3 de 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Solid-State Drive Replacement, Solid-State Drive: paso 2, imagen 1 de 2 Dell Latitude 5521 Solid-State Drive Replacement, Solid-State Drive: paso 2, imagen 2 de 2
    • Locate the solid-state drive.
    • Remove the screw on the right side of the drive.
    • After remove the screw, the drive will "pop-up" to approximately a 45% angle. Pull the drive straight out in accordance with the angle.
    • Static electricity is always a danger. Take precautions to protect the drive while, and once, it is removed.
Conclusión
Michael Engle
Miembro Desde 10/14/21
461 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 33
Todo El Tiempo: 1,172
