Saltar al contenido principal
Dell Latitude 5521 Memory Replacement
Qué necesitas
  1. Dell Latitude 5521 Memory Replacement, Base Cover Removal: paso 1, imagen 1 de 3 Dell Latitude 5521 Memory Replacement, Base Cover Removal: paso 1, imagen 2 de 3 Dell Latitude 5521 Memory Replacement, Base Cover Removal: paso 1, imagen 3 de 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Memory Replacement, Memory Removal: paso 2, imagen 1 de 3 Dell Latitude 5521 Memory Replacement, Memory Removal: paso 2, imagen 2 de 3 Dell Latitude 5521 Memory Replacement, Memory Removal: paso 2, imagen 3 de 3
    • Locate Memory on the mainboard.
    • Gently push the retention clips away from the memory module. Once you have both clips pushed away the memory module will "pop-up" on it's own.
    • Pull the memory module away from the mainboard.
Conclusión
Michael Engle
Miembro Desde 10/14/21
461 Reputación
5 Guías creadas
Un comentario
Thanks, this helped me! I noted a few things:
1.some of the screws are a little hard to get out, I think because they have lock-tite, it acts as a retainer. They had to be pulled while also unscrewing.
2.I used the iFixit bladed halberd, to pry of the case without breaking the clips. I know it's not as common of a tool, but the ultra thing blade worked well to disengage the clips gently.
3. My single 16GB DIMM wasn't cutting it. All physical memory was exhausted by the time I booted and loaded one Office file. I added a 4GB PC4-2666MHZ I had lying around, and it worked. Mixing and matching isn't recommended, but it worked in my case. Hopefully now I have some breathing room for running apps. PC/Mac vendors should stop selling units with 16GB or less. It simply isn't enough for a modern Mac or Windows (but does work fine for Linux).
Chris Alleyne-Levy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 622
