Saltar al contenido principal
Dell Latitude 5521 Battery Replacement
Qué necesitas
  1. Dell Latitude 5521 Battery Replacement, Base Cover Removal: paso 1, imagen 1 de 3 Dell Latitude 5521 Battery Replacement, Base Cover Removal: paso 1, imagen 2 de 3 Dell Latitude 5521 Battery Replacement, Base Cover Removal: paso 1, imagen 3 de 3
    • Remove the 9 phillips #0 screws from the bottom of the case.
    • Carefully pry open the base cover with your spudger. Work your way around the case slowly, being careful not to damage any of the components inside.
    • Once removed you will have access to the contents of your case.
  2. Dell Latitude 5521 Battery Replacement, Battery removal: paso 2, imagen 1 de 3 Dell Latitude 5521 Battery Replacement, Battery removal: paso 2, imagen 2 de 3 Dell Latitude 5521 Battery Replacement, Battery removal: paso 2, imagen 3 de 3
    • Locate battery in case.
    • Locate three screws that will need to be removed.
    • Locate ribbon attached to battery cable a the top left of the battery and pull straight up on the ribbon.
    • Remove all three screws holding the battery on the main board.
Conclusión
Michael Engle
Miembro Desde 10/14/21
461 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 35
Todo El Tiempo: 1,444
