Saltar al contenido principal
Dell Latitude 5480 Speakers Replacement
Qué necesitas
  1. Dell Latitude 5480 Speakers Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Speakers Replacement: paso 2, imagen 1 de 3 Dell Latitude 5480 Speakers Replacement: paso 2, imagen 2 de 3 Dell Latitude 5480 Speakers Replacement: paso 2, imagen 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Speakers Replacement, Battery: paso 3, imagen 1 de 2 Dell Latitude 5480 Speakers Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Speakers Replacement: paso 4, imagen 1 de 3 Dell Latitude 5480 Speakers Replacement: paso 4, imagen 2 de 3 Dell Latitude 5480 Speakers Replacement: paso 4, imagen 3 de 3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: paso 5, imagen 1 de 2 Dell Latitude 5480 Speakers Replacement, Dell Latitude 5480 Battery Disconnection: paso 5, imagen 2 de 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  6. Dell Latitude 5480 Speakers Replacement, Speakers: paso 6, imagen 1 de 3 Dell Latitude 5480 Speakers Replacement, Speakers: paso 6, imagen 2 de 3 Dell Latitude 5480 Speakers Replacement, Speakers: paso 6, imagen 3 de 3
    • Flip the motherboard to view the speaker cable connection on the underside.
    • Flip up the speaker cable ZIF locking flap.
    • Disconnect the touchpad ribbon cable.
  7. Dell Latitude 5480 Speakers Replacement: paso 7, imagen 1 de 3 Dell Latitude 5480 Speakers Replacement: paso 7, imagen 2 de 3 Dell Latitude 5480 Speakers Replacement: paso 7, imagen 3 de 3
    • Disconnect the speaker cable by pulling it directly out of its motherboard port.
    • Do not pull on the wires.
  8. Dell Latitude 5480 Speakers Replacement: paso 8, imagen 1 de 3 Dell Latitude 5480 Speakers Replacement: paso 8, imagen 2 de 3 Dell Latitude 5480 Speakers Replacement: paso 8, imagen 3 de 3
    • Carefully unseat the wire between the two speakers from the clips.
    • Lift the speakers up and out of the chassis.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 208
