Saltar al contenido principal
Dell Latitude 5480 Lower Case Replacement
Qué necesitas
  1. Dell Latitude 5480 Lower Case Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Lower Case Replacement: paso 2, imagen 1 de 3 Dell Latitude 5480 Lower Case Replacement: paso 2, imagen 2 de 3 Dell Latitude 5480 Lower Case Replacement: paso 2, imagen 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 141
