Saltar al contenido principal
Dell Latitude 5480 Fan Replacement
Qué necesitas
  1. Dell Latitude 5480 Fan Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Fan Replacement: paso 2, imagen 1 de 3 Dell Latitude 5480 Fan Replacement: paso 2, imagen 2 de 3 Dell Latitude 5480 Fan Replacement: paso 2, imagen 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Fan Replacement, Dell Latitude 5480 Battery Disconnection: paso 3, imagen 1 de 2 Dell Latitude 5480 Fan Replacement, Dell Latitude 5480 Battery Disconnection: paso 3, imagen 2 de 2
    • Grip the black battery cable connector loop and pull it directly up to disconnect the battery.
  4. Dell Latitude 5480 Fan Replacement, Fan: paso 4, imagen 1 de 3 Dell Latitude 5480 Fan Replacement, Fan: paso 4, imagen 2 de 3 Dell Latitude 5480 Fan Replacement, Fan: paso 4, imagen 3 de 3
    • Remove the two 3.7 mm Phillips screws that secure the fan.
  5. Dell Latitude 5480 Fan Replacement: paso 5, imagen 1 de 3 Dell Latitude 5480 Fan Replacement: paso 5, imagen 2 de 3 Dell Latitude 5480 Fan Replacement: paso 5, imagen 3 de 3
    • Grip the fan connector and pull it directly out of its motherboard port.
    • Do not pull on the wires.
    • Lift the fan up and out of the chassis.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 188
