Saltar al contenido principal
Dell Latitude 3520 System Fan Replacement
Qué necesitas
  1. Dell Latitude 3520 System Fan Replacement, Remove MicroSD-card: paso 1, imagen 1 de 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 System Fan Replacement, Bottom Case: paso 2, imagen 1 de 3 Dell Latitude 3520 System Fan Replacement, Bottom Case: paso 2, imagen 2 de 3 Dell Latitude 3520 System Fan Replacement, Bottom Case: paso 2, imagen 3 de 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 System Fan Replacement, Battery: paso 3, imagen 1 de 1
    • Slide the metal above the connector on the battery to unlock.
  4. Dell Latitude 3520 System Fan Replacement: paso 4, imagen 1 de 2 Dell Latitude 3520 System Fan Replacement: paso 4, imagen 2 de 2
    • Peel the adhesive tapes and the battery cable.
  5. Dell Latitude 3520 System Fan Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery cable from the connector on the system board.
  6. Dell Latitude 3520 System Fan Replacement: paso 6, imagen 1 de 2 Dell Latitude 3520 System Fan Replacement: paso 6, imagen 2 de 2
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  7. Dell Latitude 3520 System Fan Replacement: paso 7, imagen 1 de 1
    • Lift and remove the battery.
  8. Dell Latitude 3520 System Fan Replacement, System Fan: paso 8, imagen 1 de 1
    • Disconnect the system fan cable from the connector on the system board.
  9. Dell Latitude 3520 System Fan Replacement: paso 9, imagen 1 de 1
    • Remove the two 2mm Phillips #0 screws that secure the system fan.
  10. Dell Latitude 3520 System Fan Replacement: paso 10, imagen 1 de 1
    • Lift and remove the system fan.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 16
Ultimos 30 días: 25
Todo El Tiempo: 258
