Saltar al contenido principal
Dell Latitude 3520 Bottom Case Replacement
Qué necesitas
  1. Dell Latitude 3520 Bottom Case Replacement, Bottom Case: paso 1, imagen 1 de 3 Dell Latitude 3520 Bottom Case Replacement, Bottom Case: paso 1, imagen 2 de 3 Dell Latitude 3520 Bottom Case Replacement, Bottom Case: paso 1, imagen 3 de 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 23
Todo El Tiempo: 266
