Saltar al contenido principal
Dell Latitude 3500 Power Button Board Replacement
Qué necesitas
  1. Dell Latitude 3500 Power Button Board Replacement, Remove screws: paso 1, imagen 1 de 1
    • 10 screws hold the bottom cover in place -- these stay in the bottom cover.
  2. Dell Latitude 3500 Power Button Board Replacement, Separate bottom cover and palmrest: paso 2, imagen 1 de 1
    • Using a spudger will make quick work of this step.
  3. Dell Latitude 3500 Power Button Board Replacement, Disconnect and Remove Battery: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the motherboard.
    • Remove the 4 screws holding it in place
    • Battery can now be removed from device.
  4. Dell Latitude 3500 Power Button Board Replacement, Disconnect Surrounding Connections from System Fan: paso 4, imagen 1 de 1
    • Unplug the fan header
    • Unplug the VGA board cable
    • Unplug the LCD cable
  5. Dell Latitude 3500 Power Button Board Replacement, Remove Fan Screws: paso 5, imagen 1 de 1
    • Once these 2 screws are removed the fan will lift out as long as the cables are out of the way.
  6. Dell Latitude 3500 Power Button Board Replacement, Disconnect Ribbon Cable: paso 6, imagen 1 de 1
    • Insert wisdom here.
  7. Dell Latitude 3500 Power Button Board Replacement, Lift Left-Side Hinge: paso 7, imagen 1 de 1
    • 2 screws total
  8. Dell Latitude 3500 Power Button Board Replacement, Remove Board: paso 8, imagen 1 de 1
    • 2 screws total
Conclusión
Jake
Miembro Desde 03/08/23
1,327 Reputación
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 46
