Saltar al contenido principal
Dell Latitude 3380 Speakers Replacement
Qué necesitas
  1. Dell Latitude 3380 Speakers Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Latitude 3380 Speakers Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Speakers Replacement: paso 2, imagen 1 de 2 Dell Latitude 3380 Speakers Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Speakers Replacement, Speakers: paso 3, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Using tweezers, disconnect the power cable connecting the speakers to the motherboard.
  4. Dell Latitude 3380 Speakers Replacement: paso 4, imagen 1 de 1
    • Using the nylon spudger, pry off the velcro straps attaching the cable to the chassis.
    • The metal spudger is used in the photo, but please use the nylon one as it is ESD safe.
  5. Dell Latitude 3380 Speakers Replacement: paso 5, imagen 1 de 1
    • Using the spudger, pry off the other velcro strap attaching the power cable to the chassis.
  6. Dell Latitude 3380 Speakers Replacement: paso 6, imagen 1 de 1
    • Using your fingers, unhook the last part of the cable from this metal hook.
  7. Dell Latitude 3380 Speakers Replacement: paso 7, imagen 1 de 1
    • Gently lift the speakers from the chassis.
    • They will be attached via velcro to it so you should have some resistance. This is normal.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 110
