Saltar al contenido principal
Dell Latitude 3380 Motherboard Replacement
Qué necesitas
  1. Dell Latitude 3380 Motherboard Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Motherboard Replacement: paso 2, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Motherboard Replacement, Motherboard: paso 3, imagen 1 de 3 Dell Latitude 3380 Motherboard Replacement, Motherboard: paso 3, imagen 2 de 3 Dell Latitude 3380 Motherboard Replacement, Motherboard: paso 3, imagen 3 de 3
    • Remove the four 3 mm screws holding the battery in place using a Phillips #0 screwdriver.
    • Disconnect the battery cable by gently pulling it out.
    • Remove the battery.
  4. Dell Latitude 3380 Motherboard Replacement: paso 4, imagen 1 de 3 Dell Latitude 3380 Motherboard Replacement: paso 4, imagen 2 de 3 Dell Latitude 3380 Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the 3 mm screw from the WLAN card using a Phillips #0 screwdriver.
    • Disconnect and remove the WLAN card.
  5. Dell Latitude 3380 Motherboard Replacement: paso 5, imagen 1 de 3 Dell Latitude 3380 Motherboard Replacement: paso 5, imagen 2 de 3 Dell Latitude 3380 Motherboard Replacement: paso 5, imagen 3 de 3
    • Disconnect the audio cable.
    • Remove the entire audio card piece.
  6. Dell Latitude 3380 Motherboard Replacement: paso 6, imagen 1 de 3 Dell Latitude 3380 Motherboard Replacement: paso 6, imagen 2 de 3 Dell Latitude 3380 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove the two 5 mm screws from the fan using a Phillips #0 screwdriver.
    • Loosen the four captive screws on the heatsink using a Phillips #0 screwdriver.
    • Remove the heatsink from the motherboard.
  7. Dell Latitude 3380 Motherboard Replacement: paso 7, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement: paso 7, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Using tweezers, loosen the power connector from the fan to the motherboard, fully disconnecting the fan.
  8. Dell Latitude 3380 Motherboard Replacement: paso 8, imagen 1 de 3 Dell Latitude 3380 Motherboard Replacement: paso 8, imagen 2 de 3 Dell Latitude 3380 Motherboard Replacement: paso 8, imagen 3 de 3
    • Using a Phillips #0 screwdriver, unscrew and remove this metal plate.
    • Gently disconnect the cable under the metal plate.
  9. Dell Latitude 3380 Motherboard Replacement: paso 9, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the battery power cable.
  10. Dell Latitude 3380 Motherboard Replacement: paso 10, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement: paso 10, imagen 2 de 2
    • Disconnect the power cable that connects to the charging port.
  11. Dell Latitude 3380 Motherboard Replacement: paso 11, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement: paso 11, imagen 2 de 2
    • Disconnect the touchpad cable.
  12. Dell Latitude 3380 Motherboard Replacement: paso 12, imagen 1 de 2 Dell Latitude 3380 Motherboard Replacement: paso 12, imagen 2 de 2
    • Remove the five screws from the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 27
Todo El Tiempo: 508
