Saltar al contenido principal
Dell Latitude 3380 Display Assembly Replacement
Qué necesitas
  1. Dell Latitude 3380 Display Assembly Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Latitude 3380 Display Assembly Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Display Assembly Replacement: paso 2, imagen 1 de 2 Dell Latitude 3380 Display Assembly Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Display Assembly Replacement, Display Assembly: paso 3, imagen 1 de 3 Dell Latitude 3380 Display Assembly Replacement, Display Assembly: paso 3, imagen 2 de 3 Dell Latitude 3380 Display Assembly Replacement, Display Assembly: paso 3, imagen 3 de 3
    • Remove the single 3 mm screw from the metal bracket using a Phillips #0 screwdriver.
    • Remove the metal bracket.
    • Use a spudger to gently detach the connector from the motherboard.
  4. Dell Latitude 3380 Display Assembly Replacement: paso 4, imagen 1 de 3 Dell Latitude 3380 Display Assembly Replacement: paso 4, imagen 2 de 3 Dell Latitude 3380 Display Assembly Replacement: paso 4, imagen 3 de 3
    • Remove the two 3 mm screws (four total) from both sides of the laptop using a Phillips #0 screwdriver.
    • Lift up the bottom part of the laptop to separate the display assembly from the rest of the laptop.
Conclusión
Michael Wood
Miembro Desde 09/02/21
377 Reputación
3 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2021 Miembro de Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 12
Todo El Tiempo: 524
