Saltar al contenido principal
Dell Latitude 3190 Keyboard Replacement
Qué necesitas
  1. Dell Latitude 3190 Keyboard Replacement, Base Cover: paso 1, imagen 1 de 2 Dell Latitude 3190 Keyboard Replacement, Base Cover: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Latitude 3190 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Latitude 3190 Keyboard Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Keyboard Replacement, Battery: paso 3, imagen 1 de 1
    • Locate the battery.
  4. Dell Latitude 3190 Keyboard Replacement: paso 4, imagen 1 de 3 Dell Latitude 3190 Keyboard Replacement: paso 4, imagen 2 de 3 Dell Latitude 3190 Keyboard Replacement: paso 4, imagen 3 de 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Keyboard Replacement: paso 5, imagen 1 de 3 Dell Latitude 3190 Keyboard Replacement: paso 5, imagen 2 de 3 Dell Latitude 3190 Keyboard Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Keyboard Replacement: paso 6, imagen 1 de 3 Dell Latitude 3190 Keyboard Replacement: paso 6, imagen 2 de 3 Dell Latitude 3190 Keyboard Replacement: paso 6, imagen 3 de 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
  7. Dell Latitude 3190 Keyboard Replacement, Keyboard: paso 7, imagen 1 de 2 Dell Latitude 3190 Keyboard Replacement, Keyboard: paso 7, imagen 2 de 2
    • Use the spudger to release the small black tab locking down the connector by lightly pushing up on it.
    • Disconnect the keyboard cable from the connector on the system board.
  8. Dell Latitude 3190 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Latitude 3190 Keyboard Replacement: paso 8, imagen 2 de 2
    • Hold down the laptop securely while pushing into the two release holes using a spudger.
    • You may need to push harder than you think, you will feel it release.
  9. Dell Latitude 3190 Keyboard Replacement: paso 9, imagen 1 de 3 Dell Latitude 3190 Keyboard Replacement: paso 9, imagen 2 de 3 Dell Latitude 3190 Keyboard Replacement: paso 9, imagen 3 de 3
    • Turn the laptop over, so the keyboard is facing up
    • Pry the bottom of the keyboard using a spudger to the release the keyboard.
    • Slide the keyboard outwards, away from the computer, and lift the keyboard away from the computer.
Conclusión
Haley Smith
Miembro Desde 09/01/21
308 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-5, Saknee Fall 2021 Miembro de Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 25
Todo El Tiempo: 1,324
