Saltar al contenido principal
Dell Latitude 3189 Battery Replacement
Qué necesitas
  1. Dell Latitude 3189 Battery Replacement, Lower Case: paso 1, imagen 1 de 2 Dell Latitude 3189 Battery Replacement, Lower Case: paso 1, imagen 2 de 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: paso 2, imagen 1 de 3 Dell Latitude 3189 Battery Replacement: paso 2, imagen 2 de 3 Dell Latitude 3189 Battery Replacement: paso 2, imagen 3 de 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: paso 3, imagen 1 de 2 Dell Latitude 3189 Battery Replacement: paso 3, imagen 2 de 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: paso 4, imagen 1 de 3 Dell Latitude 3189 Battery Replacement: paso 4, imagen 2 de 3 Dell Latitude 3189 Battery Replacement: paso 4, imagen 3 de 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: paso 5, imagen 1 de 2 Dell Latitude 3189 Battery Replacement, Battery: paso 5, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: paso 6, imagen 1 de 2 Dell Latitude 3189 Battery Replacement: paso 6, imagen 2 de 2
    • Grip the battery and lift it up and out of the chassis.
Conclusión
For optimal performance, calibrate your newly installed battery after completing this guide.
2 personas más completaron esta guía.
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 144
