Saltar al contenido principal
Dell L100 U021 Large Keycap Replacement
Qué necesitas
  1. Dell L100 U021 Large Keycap Replacement, Medium Keycap: paso 1, imagen 1 de 2 Dell L100 U021 Large Keycap Replacement, Medium Keycap: paso 1, imagen 2 de 2
    • Place the prongs on either side of the keycap
    • Twist to grip the top and bottom corners
    • Pull the keycap from the board
  2. Dell L100 U021 Large Keycap Replacement: paso 2, imagen 1 de 1
    • Insert the flat end of the spudger under the medium keycap and gently press up until it pops off
  3. Dell L100 U021 Large Keycap Replacement, Large Keycap: paso 3, imagen 1 de 1
    • After removing the medium keycaps around the large keycap, gently pull up on the large keycap
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 549
