Saltar al contenido principal
Dell Inspiron n5050 Upper Case Replacement
Qué necesitas
  1. Dell Inspiron n5050 Upper Case Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your laptop over to view the bottom and locate the two locks.
  2. Dell Inspiron n5050 Upper Case Replacement: paso 2, imagen 1 de 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron n5050 Upper Case Replacement: paso 3, imagen 1 de 2 Dell Inspiron n5050 Upper Case Replacement: paso 3, imagen 2 de 2
    • Pull battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron n5050 Upper Case Replacement, Keyboard: paso 4, imagen 1 de 2 Dell Inspiron n5050 Upper Case Replacement, Keyboard: paso 4, imagen 2 de 2
    • Flip the laptop right side up. Open the laptop.
    • Gently press in the four retaining tabs along the top of the keyboard with a spudger, one at a time.
    • After the first tab is released, gently lift up on the keyboard so it doesn't lock again. Finish the other three tabs while gently lifting up on the keyboard. The keyboard will hinge up along the bottom.
  5. Dell Inspiron n5050 Upper Case Replacement: paso 5, imagen 1 de 3 Dell Inspiron n5050 Upper Case Replacement: paso 5, imagen 2 de 3 Dell Inspiron n5050 Upper Case Replacement: paso 5, imagen 3 de 3
    • Gently flip the data cable latch away from the data cable with flat side of spudger.
    • Lift the cable up and out.
    • When reinstalling cable, there are two retainer wings on the sides of the cable that the cable that lock onto the bottom of the cable latch area. When these are in place the cable is properly inserted.
    • For removing the optical drive you don't need to disconnect the keyboard ribbon cable.
  6. Dell Inspiron n5050 Upper Case Replacement, Upper Case: paso 6, imagen 1 de 1
    • Close the lid, flip the laptop bottom side up with the battery at the top.
    • Remove the 11 screws holding the upper case to the lower case.
  7. Dell Inspiron n5050 Upper Case Replacement: paso 7, imagen 1 de 1
    • Flip the laptop over and open the lid.
    • Remove the two screws from the upper case.
  8. Dell Inspiron n5050 Upper Case Replacement: paso 8, imagen 1 de 3 Dell Inspiron n5050 Upper Case Replacement: paso 8, imagen 2 de 3 Dell Inspiron n5050 Upper Case Replacement: paso 8, imagen 3 de 3
    • Gently unplug the power cable.
    • You lift up on the dark gray latch.
    • Pull the blue ribbon up.
    • Gently unplug the touchpad cable.
    • Lift up on the dark gray latch.
  9. Dell Inspiron n5050 Upper Case Replacement: paso 9, imagen 1 de 1
    • Grab the metal frame of the upper case and gently pull it away from the lower case. Disconnect the cable that says MB before removing the palmrest.
    • Work your way around the perimeter of the upper case.
Conclusión
10 personas más completaron esta guía.
Tyler
Miembro Desde 06/19/12
4,920 Reputación
16 Guías creadas
Equipo
TechForce Miembro de TechForce
Business
2 Miembros
25 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 3,212
