Saltar al contenido principal
Dell Inspiron i3558-5500BLK Wireless Card Replacement
Qué necesitas
  1. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Keyboard: paso 1, imagen 1 de 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Keyboard: paso 1, imagen 2 de 2
    • With the laptop open and facing upright, use the Spudger to pull at the notches shown in the image.
  2. Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 2, imagen 1 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 2, imagen 2 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 2, imagen 3 de 3
    • Gently turn the keyboard over to reveal the ribbon cable underneath. Remove the cable from the motherboard by lifting the white release tab and gently pulling the cable away from the socket.
    • Lift the keyboard away from the baseboard to remove.
  3. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: paso 3, imagen 1 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: paso 3, imagen 2 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Battery: paso 3, imagen 3 de 3
    • With the back of the laptop facing upright, press the switch shown to loosen the battery and remove it.
  4. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Back Cover: paso 4, imagen 1 de 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Back Cover: paso 4, imagen 2 de 2
    • With the laptop facing upright - remove the ribbon cable from the optical drive by lifting the white release tab and gently pulling the cable away from the socket.
  5. Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 5, imagen 1 de 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 5, imagen 2 de 2
    • Slide the optical drive out of the port on the right-side of the laptop.
  6. Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 6, imagen 1 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 6, imagen 2 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 6, imagen 3 de 3
    • With the back of the laptop facing upright, remove the following screws:
    • Ten 0.5 mm Phillips screws from the backboard
    • One 0.2 mm Phillips screw from the battery port
    • Three 0.1 mm Phillips screws from the optical drive slot.
  7. Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 7, imagen 1 de 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 7, imagen 2 de 2
    • Gently pry the back cover from the opposite side of the battery to reveal the internal components.
  8. Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: paso 8, imagen 1 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: paso 8, imagen 2 de 3 Dell Inspiron i3558-5500BLK Wireless Card Replacement, Wireless Card: paso 8, imagen 3 de 3
    • Identify the Wireless Card as shown in the image.
    • Remove the power couplings by gently pulling them away from the assembly.
  9. Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 9, imagen 1 de 2 Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 9, imagen 2 de 2
    • Remove the 1 mm Phillips screw shown in the image.
  10. Dell Inspiron i3558-5500BLK Wireless Card Replacement: paso 10, imagen 1 de 1
    • Gently pry the wireless card upward from the screw-side and pull outward toward the edge of the laptop to remove.
Conclusión
Nathan Ybanez
Miembro Desde 09/27/17
622 Reputación
6 Guías creadas
Equipo
Cal Poly, Team S9-G5, Banghart Fall 2017 Miembro de Cal Poly, Team S9-G5, Banghart Fall 2017
CPSU-BANGHART-F17S9G5
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 544
