Saltar al contenido principal
Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement
Qué necesitas
Resumen del Video
  1. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: paso 1, imagen 1 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: paso 1, imagen 2 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement, WiFi Half Mini PCI card: paso 1, imagen 3 de 3
    • Switch off the laptop and remove the battery.
    • The keyboard is held by 4x locking clips.
    • By using cutter, carefully lift up the one side of the keyboard and start opening the locking clips.
  2. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 2, imagen 1 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 2, imagen 2 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 2, imagen 3 de 3
    • Disconnect the keyboard cable and remove the keyboard.
    • Remove the access door screw and the access door
    • Remove the screw securing the optical drive, and remove the optical drive
  3. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 3, imagen 1 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 3, imagen 2 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 3, imagen 3 de 3
    • Remove all the screws
    • Pry the upper plastic casing off of the laptop
  4. Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 4, imagen 1 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 4, imagen 2 de 3 Dell Inspiron N5110 - WiFi Half Mini PCI card Replacement: paso 4, imagen 3 de 3
Conclusión
4 personas más completaron esta guía.
ZFix
Miembro Desde 12/09/13
191,368 Reputación
330 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,545 Guías creadas
2 comentarios
Great, cogent step by step. You alleviated the need to watch a video while including all of the key steps. Nicely done. I replaced a hard drive last year and I would have preferred this format.
Robert Gemkow - Contestar
Hi, do you know if there is a whitelist for wifi adapters in this notebook?
Artem White - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 30
Todo El Tiempo: 7,310
