Saltar al contenido principal
Dell Inspiron N5050 RAM Replacement
Qué necesitas
  1. Dell Inspiron N5050 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Flip your laptop over to view the bottom and the two locks.
  2. Dell Inspiron N5050 RAM Replacement: paso 2, imagen 1 de 1
    • Slide the two locks away from each other.
    • Sliding these locks will loosen the battery to allow removal.
  3. Dell Inspiron N5050 RAM Replacement: paso 3, imagen 1 de 2 Dell Inspiron N5050 RAM Replacement: paso 3, imagen 2 de 2
    • Pull the battery out of the laptop.
    • Your laptop's battery should be completely removed.
  4. Dell Inspiron N5050 RAM Replacement, RAM: paso 4, imagen 1 de 1
    • Remove the eleven 5mm palmrest screws from the bottom of the laptop with a Phillips #PH00 screw.
    • Remove the two 3mm hard drive screws from the bottom of the laptop with a Phillips #PH00 screw.
  5. Dell Inspiron N5050 RAM Replacement: paso 5, imagen 1 de 2 Dell Inspiron N5050 RAM Replacement: paso 5, imagen 2 de 2
    • Flip over and open the laptop to view the keyboard.
    • Use a plastic opening tool to press down on four clips, one by one.
    • Press down on the clips and pull the tool towards you to pry the keyboard loose.
    • The four clips are above the Esc, F6, F11, and Delete keys.
  6. Dell Inspiron N5050 RAM Replacement: paso 6, imagen 1 de 3 Dell Inspiron N5050 RAM Replacement: paso 6, imagen 2 de 3 Dell Inspiron N5050 RAM Replacement: paso 6, imagen 3 de 3
    • Remove the keyboard carefully.
    • Make sure to lift the keyboard gently, because a cable is connected to the back.
    • Flip the keyboard over to find the keyboard cable.
    • Pull the cable labeled "UP" out to disconnect it from the laptop.
  7. Dell Inspiron N5050 RAM Replacement: paso 7, imagen 1 de 3 Dell Inspiron N5050 RAM Replacement: paso 7, imagen 2 de 3 Dell Inspiron N5050 RAM Replacement: paso 7, imagen 3 de 3
    • Find the RAM and pull apart the two clips.
    • After pulling apart both clips, the RAM component will snap up.
  8. Dell Inspiron N5050 RAM Replacement: paso 8, imagen 1 de 2 Dell Inspiron N5050 RAM Replacement: paso 8, imagen 2 de 2
    • Remove the RAM.
Conclusión
7 personas más completaron esta guía.
Un comentario
Thanks Kristy,
I was breath new life back into an old laptop and re-purpose after upgrading the RAM.
jason acn - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 29
Todo El Tiempo: 2,393
