Saltar al contenido principal
Dell Inspiron N4110 Screen Replacement
Qué necesitas
  1. Dell Inspiron N4110 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: paso 2, imagen 1 de 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: paso 3, imagen 1 de 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: paso 4, imagen 1 de 3 Dell Inspiron N4110 Screen Replacement, Screen: paso 4, imagen 2 de 3 Dell Inspiron N4110 Screen Replacement, Screen: paso 4, imagen 3 de 3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: paso 5, imagen 1 de 2 Dell Inspiron N4110 Screen Replacement: paso 5, imagen 2 de 2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: paso 6, imagen 1 de 2 Dell Inspiron N4110 Screen Replacement: paso 6, imagen 2 de 2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: paso 7, imagen 1 de 3 Dell Inspiron N4110 Screen Replacement: paso 7, imagen 2 de 3 Dell Inspiron N4110 Screen Replacement: paso 7, imagen 3 de 3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: paso 8, imagen 1 de 2 Dell Inspiron N4110 Screen Replacement: paso 8, imagen 2 de 2
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: paso 9, imagen 1 de 3 Dell Inspiron N4110 Screen Replacement: paso 9, imagen 2 de 3 Dell Inspiron N4110 Screen Replacement: paso 9, imagen 3 de 3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: paso 10, imagen 1 de 1
    • The screen can now be fully removed from the computer.
Conclusión
Una persona más ha completado esta guía.
Abigail Keith
Miembro Desde 03/20/18
505 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 1,202
