Saltar al contenido principal
Dell Inspiron N4110 RAM Replacement
Qué necesitas
  1. Dell Inspiron N4110 RAM Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 RAM Replacement: paso 2, imagen 1 de 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 RAM Replacement: paso 3, imagen 1 de 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 RAM Replacement, RAM: paso 4, imagen 1 de 2 Dell Inspiron N4110 RAM Replacement, RAM: paso 4, imagen 2 de 2
    • Locate and unscrew the one 2.5x5 mm screw on the cover.
    • The screw does not detach from the cover. Make sure the screw is fully unscrewed before attempting to remove the cover.
  5. Dell Inspiron N4110 RAM Replacement: paso 5, imagen 1 de 2 Dell Inspiron N4110 RAM Replacement: paso 5, imagen 2 de 2
    • Remove RAM cover from the laptop.
  6. Dell Inspiron N4110 RAM Replacement: paso 6, imagen 1 de 2 Dell Inspiron N4110 RAM Replacement: paso 6, imagen 2 de 2
    • Use your fingers to separate the two metal clips from the RAM.
    • The RAM will lift up when properly separated. Do not force the RAM out of the clips.
  7. Dell Inspiron N4110 RAM Replacement: paso 7, imagen 1 de 1
    • Remove the RAM from the computer.
    • Be careful as to not touch the metal on the bottom of the RAM. This can cause damage.
    • The RAM should be placed on a non-conductive surface.
Conclusión
2 personas más completaron esta guía.
Olivia
Miembro Desde 03/20/18
773 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 765
