Introducción
Is your motherboard damaged or are you looking for an upgrade? if so, this guide will show you how to locate and replace a motherboard.
Qué necesitas
Locate the battery on the underside of the laptop.
Push the two battery clips following the direction of the arrows.
Unscrew the six 2.5x5mm screws from the motherboard.
Note that this screw may be "retained" by the loop at the end of the grounding wire.
2 personas más completaron esta guía.
2 comentarios
After pulling off the battery, the step to remove the four M2x3 mm screws was forgotten. Please update the guide.
