Introducción
Removal and replacement of the top cover gives access to many components. The top cover also includes the track pad assembly. This guide is often a prerequisite to replacing many internal components.
Qué necesitas
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
Casi Terminas!
Conclusión
