Introducción
The mainboard or motherboard is where most components directly connect to. It acts as the backbone of the computer system and one of the key components. Removal of the motherboard lets you get at the RAM, HDD, speakers and almost every other component all at once.
Qué necesitas
Using the #0 Philips head, unscrew the indicated screw.
Carefully pull the RAM cover up and away.
Remove the indicated 5.7mm screws.
Remove the smaller 3mm screws from underneath the battery compartment.
Peel back the yellow tape to expose the ribbon connector.
Unplug the ribbon cable from the motherboard.
Unscrew the two screws on the right hand speaker with the #0 Phillips Head.
Unplug the speaker connector from the motherboard.
2 personas más completaron esta guía.
3 comentarios
Please before removing the keyboard you should remove all the back screws because a couple of them are attached to the keyboard.
Also before removing the palm rest, you should remove the 6 M2x3 screws where the battery is located.
Hi, the top left screw on the motherboard (just to the right of the fan) is different than the others. What type of screwdriver do I need for this one?
