Saltar al contenido principal
Dell Inspiron N4010 Keyboard Replacement
Qué necesitas
  1. Dell Inspiron N4010 Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the laptop is not plugged into any wall outlets or the charger
    • Unlock the battery by sliding the right-hand switch to the right.
  2. Dell Inspiron N4010 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Inspiron N4010 Keyboard Replacement: paso 2, imagen 2 de 2
    • While holding the left-hand switch to the left position, pull the battery away from the laptop.
  3. Dell Inspiron N4010 Keyboard Replacement: paso 3, imagen 1 de 1
    • The battery is now fully removed and the laptop will not power on without it.
  4. Dell Inspiron N4010 Keyboard Replacement, Keyboard: paso 4, imagen 1 de 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: paso 4, imagen 2 de 3 Dell Inspiron N4010 Keyboard Replacement, Keyboard: paso 4, imagen 3 de 3
    • Using the #0 Philips head, unscrew the indicated screw.
    • Carefully pull the RAM cover up and away.
  5. Dell Inspiron N4010 Keyboard Replacement: paso 5, imagen 1 de 1
    • Unscrew the indicated 5.7mm screw beneath the RAM Cover.
    • Remove another screw above the battery release tab
  6. Dell Inspiron N4010 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Inspiron N4010 Keyboard Replacement: paso 7, imagen 2 de 2
    • Using a thin plastic tool (such as a guitar pick or spudger) at the top of the keyboard just above the F7 key, gently pry the keyboard away.
    • Move the spudger to either end at the top of the keyboard to fully undo all plastic clips.
  7. Dell Inspiron N4010 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Inspiron N4010 Keyboard Replacement: paso 8, imagen 2 de 2
    • Carefully tip the keyboard upwards and pull it slightly away from the body of the laptop.
    • Be careful not to put stress on the ribbon cable below.
  8. Dell Inspiron N4010 Keyboard Replacement: paso 9, imagen 1 de 2 Dell Inspiron N4010 Keyboard Replacement: paso 9, imagen 2 de 2
    • Carefully unclip the ribbon cable by tipping the keyboard towards the screen.
    • The keyboard is now completely disconnected.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S13-G5, Boczar Fall 2017 Miembro de USF Tampa, Team S13-G5, Boczar Fall 2017
USFT-BOCZAR-F17S13G5
5 Miembros
9 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 25
Todo El Tiempo: 1,003
