Saltar al contenido principal
Dell Inspiron Mini 1012: Keyboard Replacement
Qué necesitas
  1. Dell Inspiron Mini 1012: Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Remove the battery
  2. Dell Inspiron Mini 1012: Keyboard Replacement: paso 2, imagen 1 de 1
    • Using a Philip's head screwdriver, remove three screws: one directly below the battery and the other two to the right and the left of the two battery lock switches
  3. Dell Inspiron Mini 1012: Keyboard Replacement: paso 3, imagen 1 de 2 Dell Inspiron Mini 1012: Keyboard Replacement: paso 3, imagen 2 de 2
    • At the top of the keyboard, insert the metal spudger between the keyboard's metal frame and the body of the laptop as shown
    • When inserting the metal spudger, be sure to place the spudger under the frame and not under a key to avoid damaging the component
    • Gently lift up the keyboard starting at the top of the frame
    • Make sure that you do not damage the ribbon attached to the bottom of the keyboard
  4. Dell Inspiron Mini 1012: Keyboard Replacement: paso 4, imagen 1 de 1
    • Pull the clear tab at the end of the ribbon towards the hard drive to detach the ribbon
    • Perform steps one through four in reverse order with your new keyboard to finish the replacement process
Linea de Meta
4 personas más completaron esta guía.
Marie K Bordley
Miembro Desde 09/30/14
241 Reputación
2 Guías creadas
Equipo
Ohio State, Team 1-1, Buehl Fall 2014 Miembro de Ohio State, Team 1-1, Buehl Fall 2014
OSU-BUEHL-F14S1G1
4 Miembros
4 Guías creadas
Un comentario
After keyboard open, You can change HDD or Memory as you like.
최희욱 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 3,300
