Saltar al contenido principal
Dell Inspiron Mini 1012 Screen Replacement
Qué necesitas
  1. Dell Inspiron Mini 1012 Screen Replacement, Screen: paso 1, imagen 1 de 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: paso 1, imagen 2 de 3 Dell Inspiron Mini 1012 Screen Replacement, Screen: paso 1, imagen 3 de 3
    • Remove the battery from the device for safety. Slide the two tabs on the bottom of the computer to the unlocked position, and gently lift up the battery.
    • Remove the two rubber pieces at the bottom of the screen and remove the screws located behind them.
    • Carefully remove the plastic casing from the device.
  2. Dell Inspiron Mini 1012 Screen Replacement: paso 2, imagen 1 de 3 Dell Inspiron Mini 1012 Screen Replacement: paso 2, imagen 2 de 3 Dell Inspiron Mini 1012 Screen Replacement: paso 2, imagen 3 de 3
    • Remove the four screws on each corner of the screen. Then remove the screws located on the side of the screen.
    • Carefully unplug the ribbon on the back of the screen.
  3. Dell Inspiron Mini 1012 Screen Replacement: paso 3, imagen 1 de 3 Dell Inspiron Mini 1012 Screen Replacement: paso 3, imagen 2 de 3 Dell Inspiron Mini 1012 Screen Replacement: paso 3, imagen 3 de 3
    • Place the new screen onto the device and plug the ribbon in.
    • Replace the screws on the side of the screen.
  4. Dell Inspiron Mini 1012 Screen Replacement: paso 4, imagen 1 de 3 Dell Inspiron Mini 1012 Screen Replacement: paso 4, imagen 2 de 3 Dell Inspiron Mini 1012 Screen Replacement: paso 4, imagen 3 de 3
    • Snap on the plastic screen cover and replace the two screws and the rubber pieces at the bottom of the screen.
    • Turn the computer over and put the battery back in.
Conclusión
To reassemble your device, follow guide instructions.
2 personas más completaron esta guía.
sabinabarajas
Miembro Desde 10/17/15
372 Reputación
3 Guías creadas
Equipo
Gateway, Team 2-2, Kuhn Fall 2015 Miembro de Gateway, Team 2-2, Kuhn Fall 2015
GCC-KUHN-F15S2G2
1 Miembro
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 1,320
