Saltar al contenido principal
Dell Inspiron Mini 10 Touchpad Replacement
Qué necesitas
  1. Dell Inspiron Mini 10 Touchpad Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Touchpad Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: paso 3, imagen 1 de 2 Dell Inspiron Mini 10 Touchpad Replacement, Touchpad: paso 3, imagen 2 de 2
    • Using a spudger, gently pry the palm rest off of the palm rest bracket.
    • Carefully remove the palm rest from the computer base to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Touchpad Replacement: paso 4, imagen 1 de 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
  5. Dell Inspiron Mini 10 Touchpad Replacement: paso 5, imagen 1 de 3 Dell Inspiron Mini 10 Touchpad Replacement: paso 5, imagen 2 de 3 Dell Inspiron Mini 10 Touchpad Replacement: paso 5, imagen 3 de 3
    • Turn the palm rest assembly over.
    • Remove the four 3mm Phillips 0 screws that secure the touchpad module to the palm rest.
    • Gently lift the copper and silver foil squares on the touchpad.
    • Remove the touchpad from the palm rest.
Conclusión
Angela Wild
Miembro Desde 10/26/16
104 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team 1-4, Rose Fall 2016 Miembro de UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 619
