Saltar al contenido principal
Dell Inspiron Mini 10 Palm Rest Replacement
Qué necesitas
  1. Dell Inspiron Mini 10 Palm Rest Replacement, Battery: paso 1, imagen 1 de 1
    • To prevent injury and loss of data, ensure the device is turned off.
    • Slide the release latches out toward the edges to unlock the battery.
  2. Dell Inspiron Mini 10 Palm Rest Replacement: paso 2, imagen 1 de 1
    • Remove the battery by pulling it up and out.
  3. Dell Inspiron Mini 10 Palm Rest Replacement, Palm Rest: paso 3, imagen 1 de 1
    • Using a prying tool, gently pry the palm rest off of the palm rest bracket. Start prying from one side and slowly work your way around.
    • Carefully remove the palm rest from the computer base since it is still connected by a cable and to avoid damage to the palm rest.
  4. Dell Inspiron Mini 10 Palm Rest Replacement: paso 4, imagen 1 de 1
    • Gently pull the touchpad cable off the palm rest bracket.
    • Lift the rest of the palm rest off the computer base.
Conclusión
Bariso Shuba
Miembro Desde 10/26/16
270 Reputación
3 Guías creadas
Equipo
UW Tacoma, Team 1-4, Rose Fall 2016 Miembro de UW Tacoma, Team 1-4, Rose Fall 2016
UWT-ROSE-F16S1G4
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 5
Todo El Tiempo: 314
